Digital out from Soundcard?
Discussion in 'Computers' started by ShantballZ, Jun 3, 2003.
  1. ShantballZ
    ShantballZ Auditioning
    Jun 2, 2003
    2
    Okay, I've been running stereo sound out from my Soundblaster Audigy card to my hometheater system for some time now and was wanting to run a digital connection now. I know on the back of my soundcard there is a s/pdif digital output, but the only s/pdif cable I can find anywhere is the RCA jack size. My output is the size of a small headphone jack... (1/8" i belive)... Any way I was wondering if anybody knows of a site that I could pick up dongle or something that fits into that small hole? I know its not an optical toslink connector or the rca size digital coax, so what do I need to be looking for? Any help would be much appreciated.
  2. Danny R
    Danny R Supporting Actor
    May 23, 2000
    871
  3. ShantballZ
    Jun 2, 2003
    2
    I think that this would fit, but I don't think that that would allow the digital signal to pass through. That would be for mono or stereo sound not dolby digital. But thanks for your help Danny.
  4. Danny R
    May 23, 2000
    871
    Oops, I posted a stereo 1/8th jack, and the soundblaster manual says it needs a mono jack. Thus you'd use the following:
    http://www.radioshack.com/product.as...5Fid=274%2D897
    It'll work. The RCA version of SPDIF can use standard cables.
  5. Nick L
    Nick L Second Unit
    Nov 14, 2001
    283
    So that connector plus a standard RCA cable and your in business? I take it you connect the other end to your digital coax in, on the reciever?
  6. Nate Wh
    Nate Wh Agent
    May 21, 2003
    30
    Great this help a bunch! I'm doing the same thing..
  7. Jeremy Little
    Jeremy Little Supporting Actor
    Jun 9, 2001
    770
    Make sure that the "standard" cable is a 75-ohm VIDEO cable and not an audio one. This ensures that there is no impedance issues and that everything works all hunky-dory.
  8. Nate Wh
    Nate Wh Agent
    May 21, 2003
    30
    Ok.. so 75ohm video cable, I was at radio shak and they only had one of these Coaxial RCA connector cables and it was 40$!!.. Is this cable basically like a TV Cable connection with some RCA connectors at each end? I'd just rather make one or try an audio cable before dishing out 40$ for one of these.. thanks
  9. Jeremy Little
    Jun 9, 2001
    770
    No, they have 75-ohm video cables for MUCH less than that. Don't use an audio cable, chances are that it has an impedance of something other than 75-ohm. This means that it MIGHT work but there will be some changes to the signal and quite possibly to the sound.
  10. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    Yes, a 75-ohm video cable is ideal, but we're talking about a 1.5 Mbps signal which will be carried over a short distance of typically 3 to 6 feet. An audio cable likely won't lose enough to make a difference. Someone (it might have been someone on this forum) demonstrated AC3 decoded successfully without errors using alligator clips and a coathanger.
  11. Nate Wh
    Nate Wh Agent
    May 21, 2003
    30
    hahaha.. gator clips and a coat hanger... that's great!.. I get my dig reciever in tomorrow so i'll give the cables a whirl.. Thanks for the help
