Tom(F)
- Sep 27, 2004
Ok, so I have a new 6.1 surround system and an xbox with monster 400 component cables running to my tv. This is all hooked up fine I believe. I just bought the monster optical cable that hooks up to the component cable at the xbox and other end goes to receiver. The problem is that there is a slight delay with the action on screen and the sound coming from the speakers when playing xbox. When I switch to the analog input there is no delay. Could it just be a bad optical cable? Any help would really be appreciated.
If more information is needed to solve problem just ask.
Thanks in advance
Thanks in advance
