digital coaxial vs. standard RCA
Discussion in 'Archived Threads 2001-2004' started by Joe neiman, Dec 10, 2002.
  1. Joe neiman
    Joe neiman Auditioning
    Dec 7, 2002
    2
    Can a digital coaxial cable be used to connect a VCR to a tv/monitor in place of a standard RCA cable? standard RCA cables look so weak !
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Yes. Really there are two properties with these cable types: Connector and Impedance. Obviously the connectors (RCA) are the same- the only other issue is impedance.
    A cable designed for sigital signal will be 75 ohm- this is the same desired impedance for composite Video cables- so essentially their identical. Audio looks for 50 ohm signal path, but popular opinion is that 75ohm will work just fine for audio without any ill effects.
    So, a basic answer is that Digital Coax is essentially identical to composite video cable, and will also work fine for analog audio connectors.
    -Vince
    PS: You said "standard RCA are whimpy"-- but I assume you mean the junk cables packaged with components... there are heavy duty RCA cables designed for each application (Heavy Duty Audio, Video, Digital, whatever).
