Digital Coaxial Cable be used for Subwoofer
Discussion in 'Archived Threads 2001-2004' started by Norman L, Apr 15, 2002.
  1. Norman L
    Norman L Second Unit
    Feb 19, 2002
    261
    Can Digital Coaxial Cable be used for Subwoofer cable?
    Subwoofer cable has RCA ends and top grade cable.
    Is it overkill to use digital cable?
    Must Subwoofer cable be RCA-75 Ohm- RCA?
    Is AR Performance Series Subwoofer cable OK? It is not CoAX.
  2. Shane G
    Shane G Agent
    Feb 12, 2002
    37
    I use the AR subwoofer cable, it works just fine. There is no real need to use digital coax cable at all for subs, except for maybe really long runs. It would work just fine, if that is what you want.
    The AR's are shielded and use quality goldplated terminations, I've found them quite adequate without going too overboard in price.
  3. GabrielC
    GabrielC Stunt Coordinator
    Nov 26, 2001
    101
    Same here, I'm using an AR sub cable that I got for free with my first sub, works fine...
  4. KyleRoussel
    KyleRoussel Stunt Coordinator
    Nov 24, 2001
    99
    Can you plug an AR sub cable into the JBL PB12?
  5. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    "Sub" cables are a misnomer. Any quality RCA cable will work fine. Even a Radio Shack Gold Series cable will be more than enough.
    Brian
  6. Doug Drake
    Doug Drake Stunt Coordinator
    Jan 25, 2002
    68
    I think if it is a long run you might want to use a shielded cable, like a video cable (or Radio Shack Gold audio cables), just to help protect the signal from interference en route.
    Doug
