Digital Camcorder to PC?
Discussion in 'Archived Threads 2001-2004' started by Mark Giles, Sep 11, 2002.
  1. Mark Giles
    Mark Giles Second Unit
    Aug 30, 2002
    272
    Dazzle's Hollywood DV-Bridge transfers from sources that use analog cables and transfers the video/audio to DV then sends it to your PC via firewire. On the other hand, you can also connect a Sony Digital Camcorder with the iLink(IEEE-1394) directly to your firewire card in your PC. I'm assuming that since the Dazzle is switching the feed from digital to analog then back to digital, transfering directly from the camcorder will allow me to keep the quality of my video (or at least the closest) to the original images, correct?
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    If you plug the camcorder into the Bridge's firewire port, it'll just pass the signal and won't do anything to it. You don't want to hook up via analog, otherwise it'll just do the needless conversion like you stated.
  3. Mark Giles
    Aug 30, 2002
    272
    Jeff, does the Bridge have an input and output connector or is it just output. I didn't remember seeing or reading anything about having 2 plugs for connecting the 1394.
  4. Mark Giles
    Aug 30, 2002
    272
    Ok, I think I found the answer to that question here .
    Thx for the help Jeff [​IMG]
