Kevin. W
- Oct 27, 1999
I have Digital Cable going into my Panny 47 and was wondering would sending the signal through S-video from the cable box be better than through the cable itself?
Kevin
Kevin
but I can't get a picture using s-videoYou have to make sure you use set the TV to the appropriate input. More than likely Video 1. It won't show a pick on channel 3 or 4 through s-video.
Kevin
Our local provider is Time Warner, and I'm wondering if they're any good.Man,
I notice you're from NYC. I have recently seen Time Warner digital cable in NYC and was very disappointed. The signal is low-resolution, with unacceptable graininess and digital artifact. This signal is far inferior to the digital cable signal which I receive from Comcast in Baltimore, MD.
I would highly recommend going with DirectTV if your apartment building allows the installation of a dish and the surrounding buildings do not obstruct the view to the satallite.
Elias
