seth_petry_john
- Oct 12, 2003
Can anyone recommend a good digitial audio selector? You know the story: I have more sources with digitial audio out than I have inputs on my receiver. My receiver has one Toslink and one coax connection for digital audio. My DVD player uses the coax, and everything else that I want to hook up uses Toslink so I only NEED an optical audio switch.
I want something that I can integrate with the macros on my home theater remote so I need discrete remote codes for each input.
I'm worried about signal quality: do selectors like this affect the audio qualify in any perceptible way?
I've done some research and found some unit that do what I want. Does anyone have any experience with these models? Any advice?
Inday DA4X-R - $119
inday.com/da4x/da4x.htm
Radio Shack 15-1987 - $99.99
radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=15%2D1987
Audio Authority AA1177 - $119.99
digitalconnection.com/products/audio/aa1177.asp
Cables to Go 3/1 Switch - $79.99
tigerdirect.com/applications/SearchTools/item-details.asp?sku=C184%2D28731
As much as I'd like something like the Zektor component video/audio switch, that's a little out of my budget at this time.
Thanks in advance,
Seth
Inday DA4X-R - $119
Thanks in advance,
Seth
