Sidney
- Feb 1, 2005
I've been needing to get some digital audio cable to buy to connect my DVD Player to my Denon 3805 via optical cable. Is there anything I need to know when I buy one? ie type of connectors, level of quality..
Also where would you recommend to buy some good optical cable for a good price? I see things from bluejeans.com and others but how good are they with optical. I can see buying video component and regular audio cable from them, but optical..
Considering optical is digital light signals.. I'm wondering if there's really any difference between a expensive cable and a fair price cable as long as the connectors provide a good enough connection to transfer the laser light..
Well let me know which companies are good to buy from since I'm not sure what to do at this moment.
Thanks.
Thanks.
