I found two 2nd hand The 10th Kingdom DVD set in both digipak case and a normal plastic case. The plastic case is a bit expensive than the digipak one and digipak, probably because it being a cardboard, looks slightly damaged, especially the edges, not that much though.
Should I choose one over the other considering future preservation as well? What are your preferences? Does normal plastic case worth being a bit expensive over digipak?
The images of digipak from the seller:
The images from plastic case from the seller:
