Julio De Luis
- Dec 13, 2001
Hello everybody.
One of the main problems I have living in an apartment is that too much noise may be going into my neighbors apartment. The only part that connects to my neighbors is the rear wall. Even though the neighbors have not said anything, I am still concerned that they are being bothered by all the noise.
The only way i could think of difusing the sound from getting into my neighbors apartment is by covering the rear wall with acoustic wall panels from Parts Express.
The only problem with this is that the rear wall must be reflective and by covering the whole wall with acoustic wall panels i may make the room sound awful.
The room isn't that big because everything is located in my bedroom which is only 10X10X8. Putting the system in the living room isn't an option because it will disturb my mom.
So my question is, do you think i should cover the rear wall with acoustic wall panels, which are only $12.90 a 24" x 24" and is 2" thick a sheet, or just leave the wall as it is.
If you have different suggestions, like cheaper material that i could use or any other suggestions,, it would be gladly be taken into consideration
