difficulity evaluating speakers
Discussion in 'Speakers & Subwoofers' started by MarcCh, Dec 20, 2005.
  1. MarcCh
    MarcCh Agent
    Feb 18, 2004
    38
    I was wondering how one goes about evaluating new speakers when there is no place to listen to them around where I live. I am not real great at the suttle differences but what should I do. Any help is greatly appreciated.
    Marc
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    You can only go by looks and reputation.
    Just look at your wallet and decide what you could spend, then determine what music you really care about the most. I like Classic Rock, some classical, no rap or electronic. So, midrange (1) and bass (2) are most important to me.
    Also I don't need anything to play really loud, so sensitivity isn't an issue.
    I don't need rosewood.
    I look for speakers that are known to image well. Most do, some are better than others.
    Read, read, read, then just buy. Don't torture yourself.
    Live with your decision, and keep your eyes open for the next best thing. Change or collect freely.
  3. Dick Knisely
    Dick Knisely Second Unit
    Oct 22, 2005
    372
    Order from someplace that will let you return them for any reason or no reason at all. They exist and in your situation it will be worth hunting them up. One such is Cambridge Sound Works.
    www.hifi.com
  4. mackie
    mackie Supporting Actor
    Feb 7, 2004
    568
    Also, go to the manufactures websites and and use the dealer locater search function. Don't know where you are, but there might be a few closer than you think.
  5. Matt Rohr
    Matt Rohr Agent
    Dec 15, 2005
    40
    Almost any local home audio shop will let you take them home for a trial run. I did that with my home speakers I have now. They let me take home 2 different brands! I am glad I did, They sounded alot nicer in my home. But you should try to find someone local so you do not need to worry about shipping headaches.
