Differences in RG-6 cable? (1 Viewer)
Tim Holyoke
I usually get my coax from Radioshack since it's the only place that really carries it in my small town. I live in the country, and have satellite, so always got the RG-6 that was labeled "satellite coax." There is also "TV coax." Is there really a difference? I only ask because I have 50' of "TV coax" sitting around and I need 50' for a new satellite run. Thanks a lot for any help.
Tim
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
There is a difference, Tim. You’ve probably noticed that the “satellite coax” (better know as RG-6) is thicker overall. It has a thicker center conductor, and the dielectric (the white insulator around the center conductor) is a larger diameter than the “TV coax” (better known as RG-59). Those differences are critical to delivering the best signal for satellite. Using RG-59 can degrade picture quality, like giving vertical bars or lines in the picture on some channels.
Broadcast signals work fine with RG-59 or RG-6.
Wayne A. Pflughaupt
Tim Holyoke
Thanks for the replies guys. I should have mentioned in my original question that both were RG-6. After actually looking at the cables, not just the box itself, I found both the "TV coax" and "Satellite coax" had all the exact same numbers (RG-6, 75 ohm, 18 AWG). The only difference was that the satellite one said "satellite" on the cable. So if the numbers are all the same, are they the same? Maybe they just call one "satellite" so they can charge a few bucks more? Thanks again.
Tim
MikeRo
Well, if they are both marked as RG6, I would say that either one would work. You can't hurt anything by trying the cable you already have anyway. They probably did mark one as satellite so that they can make a few bucks extra.
Chu Gai
I'd look at the center conductor to see if it's 100% copper or copper over steel. When one is dealing only with frequencies above say 50 MHz, you can use the latter as the signal is largely located on the 'skin' of the conductor and the steel carries nothing. Hence there's no reason to use all copper which is more expensive.
Kenneth Harden
Well, at Best Buy, a 6' chenk of RG-6 is $6.99, so it is probably worth it to splurge.
I would like to try a piece of RG-59 and see if there really is a difference.
Chris Lanni
Christopher
Hi guys...
RG6 is what all of your cable companies run for your cable tv. It is also what is used for satellite television. Usually you will find that there is a seperate ground wire running along the outside of the "satellite" RG6. RG6 has an 18 gauge center conductor, whereas, RG59 has a 22 gauge center conductor. You really do not want anything to do with RG59 as it is obsolete. If you have two cables and they both are stamped RG6 along the side of the wire then they are the same, unless one says quad shield. Then it just has an extra pair of shields.
Gods Love
chris
Chris Lanni
Christopher
Hi guys...
Gods Love
chris
Leo Kerr
RG-59 is obsolete?
Odd that Beldin probably sells more RG59 than any other cable that they make...
Starting next week, our contractors are probably going to start pulling in one or two miles of '59...
Now if you want an obsolete cable, look at RG-117.
Leo Kerr
[email protected]
Chris Lanni
Christopher
Hey Leo...
Out of curiosity, what are you using the RG59 for? What do you usually pay for the cable whether by foot or spool? I do not sell cable and am in no way affiliated with anybody, just curious.
Gods Love
chris
P.S. I should have said obsolete for Home Theater use. I must not be getting enough sleep.
Chu Gai
What possible difference would there be in interconnects or a component video run of several meters or for that matter, 50 feet?
Chris Lanni
Christopher
Chu...
I am only going off the original topic. Which is satellite tv. RG59 is wholeheartily not recommended for Satellite. Everything that I have read lists RG6 as the recommended cable. Now some say that you can use RG59 from the tv to the receiver, but not to the dish. I say why would you buy two different size cables when RG6 is a better quality and is similiarly priced? Now keep in mind that I live in Ohio and can only speak from my "area" of expertese.;)
For what you are talkin' Chu, you are right. RG59 would probably be fine for component and interconnects. Again it goes back to cost. Why pay the same price just to get RG59?
Chu Gai
Because it's more flexible, puts less strain on connections, the bandwidth of the signal from your player even if running 1080i is a piece of cake, and the attenuation drop compared to RG6 over a few meters will tax sophisticated measuring devices...stuff like that.
Brian Fellmeth
I am trying to use a 25 foor RG6 cable with F to RCA converters from HD for a composite video signal, and it doesn't work. There is a crawling band artifact that is not present with what should be a far lessor cable. Frustrating.
Leo Kerr
Well, we get the RG-59 by the 500 or 1000 foot spool, and the runs are anywhere from about 30' (DVD player through the racks the to distribution amps) to about 1500' (distro amp, through the conduit and cable troughs out to a display somewhere else.)
We use a variety of Beldin and West Penn wire, depending on who supplies it - the stuff we buy is the Beldin, usually 8241.
On the RG-6 side, I know a lot of people who won't use anything but Beldin 1695A, for any purpose. I suppose its a nice enough cable, but it's difficult to get in long rolls, and all of our infrastructure (crimpers, dies, strippers, and ends) are already in place for '59.
8241 is conveniently available for $0.13/ft (in 1000' spools) from Markertek... we might be able to get it for $0.11/ft or so.
Leo Kerr
StephenHa
I use nothing but rg-6 (I like only needing one type can't grab the wrong one from the truck) direct tv and dishnetwork will charge a dealer back all commisions if rg-59 is used, (good incentive not to screw up)
Homestar9
