Jeff O.
- Jun 12, 1999
I know a number of people have recommended regular cleaning of connectors. I have heard Caig pro gold mentioned as a good one. However, I have a couple of questions. If I go to Parts Express there are a number of different formulations that appear to do very similar things, Deoxit, Pro gold and R5. Are there specific applications/recommendations for each of these and what works best for audio connections? If you read the info, it sounds like they all do the same thing. I used to use this stuff called Tweak (I think) and it worked great, but if you got it on plastic, it eventually destroyed it. Are any of the above more forgiving when you have connectors with plastic around?
Jeff
Jeff
