Differences between toshiba theaterwide and cinema (1 Viewer)
Art Vance
Grip
Is the picture better on the Cinema series RPTV's as opposed to the theaterwide series?
I have a chance to get a 57h84. Should I get the 57hx93 instead? would the picture quality be much better on the 57hx93?
Any other info on this subject would be beneficial as well.
thanks,
Art
Jeff W.
The HX "Cinema" line is supposed to be the upgrade from the H.
It's hard to tell from reading the specs but the biggest difference that I can see is the HX has "PowerFocus HD4" CRTs while the H has "PowerFocus HD II" CRTs. Is the "4" CRT really that much better than the "II"? Who knows?
Jeff W.
MSC
