Differences between SVS PCi and PC+?
Discussion in 'Archived Threads 2001-2004' started by VinhT, Sep 25, 2002.
  1. VinhT
    VinhT Second Unit
    Feb 14, 2002
    357
    What are the differences between the SVS PCi series and the PC Plus series other than the more powerful amp, adjustable subsonic filter, and tunable ports? Is the frequency response pretty much the same? Does the Plus have greater excursion, etc.
    I ask because I don't really need a fancy sub, I would just like a nice one that has the ability to be run quite hot (sadly, my DIY sub is not up to the task). However, if the PC Plus is clearly superior to the PCi, then I'm prepared to go for it.
    Also, just a miscellaneous question. It seems that the Ultra is very flat, but does not go as low as the CS/PC series. Is that correct? That's the impression I got from the charts shown on the site.
  2. Ned
    Ned Supporting Actor
    Feb 20, 2000
    838
    I believe the PC+ also has the better driver like in the CS+. That probably gives another 2-3db of maximum output.
