Differences between CD-R and CD-DA?
Discussion in 'Computers' started by Patrick Sun, Nov 28, 2003.
  1. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    Can you use CD-DA (the CDs designed for use in the standalone CD replicator) in a conventional CD-R burner and burn them like a CD-R? I do know that CD-DAs have that RIAA-type of royalty tax applied to them, so they tend to be more expensive.
  2. Greg_L_C
    Greg_L_C Stunt Coordinator
    Mar 9, 2002
    126
    Yes you can Pat, but not the other way around, Audio only cd's have a byte pressed in them at the factory that the stand alone recorder looks for. They should work fine in your pc cd.
    Greg
  3. Patrick Sun
    Jun 30, 1999
    38,717
    463
    Ah, that makes sense. Thanks.
