Differences between 50H81 and 50HX81
Discussion in 'Archived Threads 2001-2004' started by Miles_W, Jan 10, 2002.
  1. Miles_W
    Miles_W Second Unit
    Aug 16, 2000
    436
    In non technical terms what exactly is the difference between these 2 tv's??
  2. JoeDelan
    JoeDelan Stunt Coordinator
    Nov 1, 2001
    78
    If I am not mistaken, Better Speaker, Bigger lenses and anti-glare screen. Worth the difference in Price? Depends who you talk to.
  3. Robert Barker
    Robert Barker Stunt Coordinator
    Oct 22, 2000
    66
    HX has tweeters, better glare screen, and larger lenses.
    The woofers on the two TV's are the same.
    I own a 50H81 and am very happy w/ it. I have restacked my screens, so I no longer have glare. I don't use the TV's speakers, and due to the 50 inch screen, the 7 inch lenses work just fine. If I had a 65 inch this may come into play. I could not justify the extra cost of the HX. I also had Sears pricematch the lowest internet price I could find. I had the TV delivered and set up for a total of 2080.00, that's with tax.
    Robert Barker
    Austin TX
  4. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    Miles, the differences are the CRTs, lenses, lenticular screen (blackstripe on HX), protective screen (anti-reflective), sound system and cosmetics.
    If it doesn't break the bank, the differences, IMHO, are worth the price. The CRTs are designed to give a much longer life and if you held both lenses in your hands, you'd be sold on the HX in a heatbeat. The picture on the H is great, the HX is stellar.
  5. Miles_W
    Miles_W Second Unit
    Aug 16, 2000
    436
    Gentlemen thanks for you help!
  6. ace peterson
    ace peterson Second Unit
    Jun 4, 2001
    340
  7. Andrew s wells
    Andrew s wells Second Unit
    Nov 20, 2001
    449
    Just wanted to know...i keep hearing conflicting answers, so.....does anyone know if the 50H81 does 3:2 pulldown? I am getting my set tomorrow and needless to say i am quite excited. Thanks in advance.
  8. JohnnyG
    Dec 18, 2000
    1,522
    Yes it does.
