Difference between the 45TX and the 53TX
Discussion in 'AV Receivers' started by ToddP, Nov 5, 2003.
  1. ToddP
    ToddP Stunt Coordinator
    Sep 15, 2003
    172
    The only difference I can see between the 45TX and the 53TX is the remote. Is this correct? Are there part differences? Is the 53TX simply an upgrade to the 45TX?? Thanks for the info.
  2. Jon_Welker
    Jon_Welker Second Unit
    Apr 29, 2003
    404
    I believe the 53 does not have USB either...
  3. Richard_B
    Richard_B Stunt Coordinator
    Oct 14, 2003
    137
    They are pretty much the same receiver. Both are pretty darn good too.
  4. Don Barduca
    Don Barduca Stunt Coordinator
    May 9, 2002
    66
    Todd,
    First and foremost: Sonically both have the same guts and the same sound.
    Differences:
    53tx has:
    - Audio sync/delay (Manual, but more precise than standard .5 increments that MCACC does on both units.)
    - on-screen display is cabable of use thru component inputs not just s-video or composite.
    53tx lacks:
    - Backlit & LCD remote (LCD provides easy recognition of active component and certain features) (Backlit self explanitory.)
    - RS-232 port (can potentially allow for upgrades)
    - USB port (quicker connection to a PC)
    - 3 lbs. of weight??? (don't know if the weight loss is caused by the lack of features above or not. But likely.)
