Difference between subwoofer & digital coax?
Discussion in 'Archived Threads 2001-2004' started by Sal Conigliaro, Dec 22, 2001.
  1. Sal Conigliaro
    Dec 11, 2001
    28
    Is there any difference between a 'subwoofer' cable and a 'digital interconnect' (ie, between DVD's digital out & receiver) cable?
    Aren't they both usually just 75ohm coax?
  2. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    Standard Audio cables are typically 50 Ohm cables, cables identified as Digital or Audio/Video are 75 Ohm cables.
    For your sub the standard audio cable would work, but getting the 75 Ohm cable means you get more flexibility to use that cable on the video or digital side if you need to.
    BruceD
  3. Walt H
    Walt H Stunt Coordinator
    Aug 5, 2000
    209
    Do you think a Digital or Audio/Video 75 Ohm cable will produce a better sound when connected to the subwoffer as opposed to the standard 50 Ohm audio cable?
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    For any audio application, subwoofer or regular component interconnects, no difference in performance between 75 ohm cable and "std".
    And especially for subs with low freqs.
    But if you have 75 ohm cable around, certainly not going to make it sound worse either. Just not necessary.
    You only need "shielded", preferably gold terminated cables.
