difference between composite video and audio cable
Discussion in 'Accessories, Cables, and Remotes' started by Phil_La, Oct 28, 2003.
  1. Phil_La
    Phil_La Stunt Coordinator
    Jul 19, 2003
    86
    Is there any difference between using 2 composite video cables instead of 1 audio cable with two RCAs on each end? We'll say this is for sending audio from a TV to a receiver.
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    You can use most RCA cables for audio. They dont care about the impedence. In fact, many audio cables are made with the same 75 ohm impedence coax used for video cables.
    But dont do the opposite: use a audio cable for video. (ok, you can try it, it wont damage anything). But coax comes in 50/75/110/300 ohm flavors. Video connections are designed for 75 ohm coax.
  3. Phil_La
    Jul 19, 2003
    86
    That's what I thought, thanks.
    I ended up buying some NXG Sapphire series cables. They were listed as "works as digital coaxial, composite video, and subwoofer cable". I'm assuming that means they're 75 ohm.
