sean strugnell
Grip
- Sep 27, 1999
Hey,
Anyone know if there is much of an advantage going with the 1124 model over the 1100 model Behringer Feedback Destroyer?
All I could find on the net is that "Also note that the DSP-1124 is an upgraded version of the 1100 with the differences being a 24 bit AD/DA converter in the 1124."
Does this ad/da converter matter much for the purposes of EQ'ing a sub? I would not think it would make much difference, as I would be dealing with analogue in and analogue out, right?
Seems like the 1100's can be had for a lttle less than the 1124's, and I am saving for a projector & screen to replace my puny 32" TV.
Thanks.
Thanks.
