Kajs
- Jun 22, 2001
- Kurt
Has anyone seen this on Ebay? It has some trailers and featurettes on it.
The packaging says:
"WARNING! Once removed from its packaging, the DVD will self-destruct in 36 hours!"
According to Q's letter: "By self-destructing, I don't mean the DVD will explode or vanish into thin air, so please restrain yourself. It's as simple as this: once you remove the DVD from its packaging, you only have 36 hours to watch it. Play it in a conventional DVD player or DVD-ROM drive as much as you'd like, but 36 hours after removal, you will no longer be able to access the content on the DVD. It then makes a nice martini coaster."
Is this possible?
The packaging says:
Is this possible?
