ok to start i have a compaq presario with a 40 gig hard drive. or at least i did.
the other day it shut itself off then rebooted.
when it came back on it was displaying what looked like maybe dos, i dont know because i am truly a novice on this type of thing.
anyway the windows xp screen never came back on.
so i rebooted again and nothing.
so i put the compaq restore cd in to see what it would do and after running for a minute or so a big red screen came on that said call compaq for service, or something close to that wording.
so i did but since it is out of waranty they wanted me to pay $30 just to try and help with what was wrong.
she wouldnt even answer any simple questions i may have had.
like can i replace the hd with a new store bought one and how do i get back all the installed programs onto the new hd.
so does this sound like a hd crash?
what is the risk of my buying another hd and installing it? if that isn't the problem are hard drives returnable if i can't use it?
what happens to all the programs that origionally came with the computer? are they on the restore cd?
i had norton and was always updated so i shouldnt have had any virus but what if i do. how do i know?
becausee it will likely destroy anything else going on this pc.
any advice would be hugely helpful.
td
td
