Manuel Delaflor
- May 25, 2001
I have made calculations for a driver I can get for about 85 bucks. Yes, I would love to get a Shiva instead but for me the cost would be around 200 bucks.
I have a 12" sonotube and the driver I can get mounts on a 11" diameter, so I hope it can be done. Here are the parameters:
_______________
12" unit:
voice coil diameter : 2½
speaker displacement : 1.98 liters
FS: 22 Hz
Qts : 0.355
Qms : 12.880
qes : 0.365
Vas : 176.22 liters
Xmax 17 mm
Revc 3.6 ohms
________________
I don't know how to compare that to those on Shiva (meaning I don't know if it is a bad driver or a comparable one). The volume of my sonotube is 697 liters and the ISD Online Im using is at:
http://www.linearteam.dk/newdriver.html
I filled the driver parameters, selected a vented enclosure and filled the box volume in liters and the tuning frequency was 16Hz
The resultant graph seems good from 20Hz to 50Hz is about -3dB and it have a big bump around the 16Hz of tunning frecuency. The port should be 3" and 27cm long.
Is there something important I have missed? Are my calculations correct and I can expect a good subwoofer??
Thanks to all that have helped me to get here (specially to Jack, which always encouraged me, not that I liked specially, to do all that Im doing now).
_______________
12" unit:
FS: 22 Hz
Qts : 0.355
Qms : 12.880
qes : 0.365
Vas : 176.22 liters
Xmax 17 mm
Revc 3.6 ohms
________________
