Lew Crippen
- May 19, 2002
Rick, is your center speaker rear ported? This could make a big difference if it is in some kind of shelving.
This is fine for special listening situations, such as actual night listening so as not to annoy others. But it reduces the fidelity of your system to one of significantly lower quality. A real movie theater does not make such compromises in sound.However, this is home theater, not a movie theater.
In purist terms, compressing the dynamic range is a reduction of fidelity. Other than decreasing the available dynamic range, how is this approach reducing the fidelity of reproduction?
Thanks (in advance) for your response.
However, this is home theater, not a movie theater.I think that's the fundamental difference between our points of view. It seems to me that home theater owners go to an awful lot of trouble to reproduce the move theater experience - high picture resolution, carefully balanced color, high quality sound, popcorn poppers, etc.
If the goal of a home theater ISN'T to provide an experience of equal quality (including dynamic range) to a movie theater, then you are right. If HT owners want to recreate the movie theater experience, then the sound conditions should be the same.
Of course, if you're just watching TV in your home theater, that's different. Broadcasters already adjust the sound range accordingly.
If the goal of a home theater ISN'T to provide an experience of equal quality (including dynamic range) to a movie theater, than you are right. If HT owners want to recreate the movie theater experience, then the sound conditions should be the same.
This is true if there are only 2 types of enthusiasts but I think the case is 3 types. First type are the audiophiles that create an actual movie theater in their home, which really can not be classified as a home theater because of what the theater consists of. Second type would be those who create a home theater that is pretty high end, and third type is those who just want good sound and a good experience without having to put their home on mortgage. The important thing here would be budget, how much are you willing to spend would most likely decide which type of enthusiast you are.
What John said about the listening levels I find true. Listening to an action movie at -20 db prevents the dialog from being washed out because the dialog is loud at -20 db. When a huge explosion takes place in the movie, it will be loud which may make the person listening to the movie, uncomfortable. Now this I would assume is how a movie theater is set up. But in a home theater set up by the 3rd type of enthusiast, the room is alot smaller than a movie theater, so it sounds 20 times louder than it might in a movie theater.
To some people, this is fine, and one would venture to say that , if the person is uncomfortable with such sound levels, why create a home theater area in the home, but you already know the answer to that one.
Now a trick to do is when dialog is present in a soft movie, adjust the volume to where you hear the dialog clearly, then remember this volume setting because most likely it will be your minimum volume when watching a movie give or take a few decibels.
The main problem with the above is the listener may not have the luxury to increase the volume to where the dialog is perfectly clear without having to change the volume during explosions, such as my case. I think what the problem boils down to is when the user has a home theater set up and wants to have a movie theater experience but has audio limits such as apartment's adjacent to the set up, neighbors near by, etc.
My problem will be fixed by bringing down the front and center speakers to around the listeners ear level instead of 6' off the ground, and scheduling to watch movies when I know I have no audio limit at that current time. I realized my problem is that the minimum volume I can listen to while watching a movie without disturbing others is too low to compensate for the dialog. Only way I can over come this drawback is to ride the volume - Constantly change it. I need a sound clipper that clips the volume to a specified cap
Thanks everyone for the help and you can continue to post for this thread because I'll keep reading as long as posts are posted
Of course, if you're just watching TV in your home theater, that's different. Broadcasters already adjust the sound range accordingly.This is true for SD broadcasts, with rampant compression, however the HD broadcasts seem to be much better produced. I'm assuming this isn't just because of the usage of DD.
Besides, the best PQ on HDTV is stunning indeed.
