Desperate! Please help with XP recycle bin problems
Discussion in 'Computers' started by Michael Pedrosa, Apr 22, 2003.
  1. Michael Pedrosa
    May 21, 1999
    34
    Can someone please help? Admittedly, this is not a home theater question but I've tried everything and can't fix my problem. I've looked on Microsoft's support page, tried other "computer" forums, but found nothing. So I'm back to a trusted and helpful forum.
    The problem: My recycle bin exceeds the size that I set in the properties box. No matter what I set (even 0%), the recycle bin just holds on to all the files until I manually go in there and clean them out. I work with large numbers of large files so that I should quickly "fill" the bin and older files should automatically be purged; but that doesn't happen.
    I've tried some of Microsoft's suggestions (deleting the info file, deleting the recycled directory) but they haven't resolved anything. I have Norton Utilities installed but have verified that the Norton Protect feature is off (the problem started long after installing Norton, anyway).
    I'm using Windows XP,regularly "auto-updated." Other than Norton Antivirus and Zone Alarm, there are no background programs running. I do not use any undelete or disk imaging software.
    Any ideas?
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    How large is your hard drive?
    Although you can set your bin to zero I don't think XP can actually do that. I wouldn't be suprised if the only way you could do that would be to do a permanent delete with every file.
    Brent
    P.s. hold down the SHIFT key to permanently delete something . In the properties page for the bin you have the option to permanently delete everything without it ever going into the bin.
  3. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    I think I remember reading a few solutions to your problems at www.tweakxp.com . You may want to check them out.
  4. Michael Pedrosa
    May 21, 1999
    34
    Brent,
    I don't want to set my recycle bin to 0% or to bypass it and permanently delete everything. I want to use it but it needs to stay at the size I set.
    I have two hard drives - 40gb and 80gb (and the problem is still there whether I use individual or global size settings).
    Todd,
    Any specific memory of where to find that info? I searched their forum but couldn't come up with it.
    Thanks to both you guys.
