BrettisMckinney
- Aug 25, 2002
Im soo close to giving up here :frowning:
I have a rectangle shaper lounge with tv against a wall at the front, Monitor 7's spaced perfectely either side with about 2 meters from the corner. I'm using a Sony SW40 with a Yammy rx496 amp. All speakers are set to small, and LFE to SW.
So far i've tried both left and right corners and in sitting position the bass is kinda then..tho nearly alright..but if i stand up..its like DAMN! where did all THAT bass come from! I then tried moving against the side walls facing inwards...this still didnt make a difference. In my listening position there just isnt half the bass there is like when i stand up. ANy ideas? Its getting on my nerves bad. I have crossover set to about 100hz too.
