Brian.Huep
- Jul 25, 2003
Hello guys, As the title denotes, I am looking for...
An Svs sub to fill a 15x11x7 room. The back wall is only a velvet curtain though, so technically there is another 15 feet behind us. There is an unclosable doorway midway back leading into a 30x11x7 room. (Its a split in half basement with a load bearing wall right down the middle)
I was thinking about the 16-46plus one I think it is. The biggest cylinder one. 16hz, 520watt. Is that overkill?
I Will be running a HK 325 receiver, 2 Klipsch Quartet mains, Klipsch academy center channel, and 2 crap pioneer rears.
I am also wondering what rears people would recommend. Keep in mind they will be right against the back wall, (which is only a curtain though), so I am unsure if dipoles, or tri's would work.
Any ideas guys?
Any ideas guys?
