Chris_Kelly
- Apr 18, 2002
Hello fellow DIY'ers
My first posting here on the forums. The forum came highly recommended for matters dealing with sonosubs....hence, my arrival.
To matters at hand.
I'm looking at building my first sub and have decided to make a go at a SonoSub. I've been trying to find and read everything I can regarding this type design.
It seems to me that for this type of sub, the construction parameters should be pretty well nailed down by now. I've been doing a LOT of looking at the Shiva 12" driver (specifically the MKIII). I'm open to suggestions for other drivers tho.
So, I'll now try and tap into the wealth of knowledge contained here in these forums and try to finalize a design for my Sonosub.
What am I wanting?
*Hmm...90% Home Theatre use.
*I'm in a temp. house right now (student) so the sub will most likely be overkill for the room...that's ok though. I want to build the sub with the idea of what kind of room it WILL be in the very near future.
*I would like to have a pretty flat response down to 20Hz.
Accuracy and low distortion are important.
*Size and shape are open to consideration at this point. I just don't want a 6ft tall 24" diameter monster though
*I want to keep it down to just a single 12" driver.
*Ported/Unported - Dunno yet. Leaning towards ported for sizing reasons tho.
Does anyone have anything to say regarding just using the Adire WhitePaper specs for cabinet/port sizing when using the Shiva?
btw...the rather restrictive user name nomenclature is annoying...just had to mention that.
Peace
To matters at hand.
What am I wanting?
Peace
