Saydee
- Apr 8, 2004
I'm planning on building this sub in the next few weeks according to the plans found on Adires website. I selected the PE 250W plate amp. My question is where or how are you getting the plate amp to fit in the box? Are you modding the brace design? Fitting the braces between the components of the amp? Changing the dimensions of the plan?
Any hints or tips on building the 54L?
Thanks.
Thanks.
