Dented Tweeter.
Discussion in 'Speakers & Subwoofers' started by Brendan D, Sep 2, 2004.
  1. Brendan D
    Brendan D Auditioning
    Mar 2, 2004
    13
    The other day I was cleaning off my speakers (B&W 601's)...when I took off the faceplate, I noticed that the Tweeter dome on one of the speakers had "caved in". After testing both speakers (the other one was fine), I could not detect a difference in sound. Does anyone know if the sound quality is lessened by this? I would assume it is, but cannot tell by listening. I played several types of music and movies to try and discern.
    Thanks!
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    I guess theoretically it could affect imaging, but I doubt you’ll actually notice a difference.
    There are various methods you can use to try to pull it out – a piece of tape (masking first, duct as last resort), vacuum cleaner nozzle for starters.
    Wayne A. Pflughaupt
  3. Brendan D
    Mar 2, 2004
    13
    Thanks. I will try that tonight when I get home.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Stick the masking tape to something else first, to make it a little less sticky, then it should pop the dome right out. As long as there is no crease, it should be perfectly fine.
  5. DonJ
    DonJ Second Unit
    Mar 5, 2002
    293
    I would by a new tweeter dome and have it installed at the dealer.
  6. Scott Stephens
    Scott Stephens Stunt Coordinator
    Dec 23, 1999
    130
    Great info. I just noticed the same thing with one of my tweeters (and I couldn't discern any decrease or difference in sound quality, either) a couple of weeks ago.
    I will try the masking tape and vacuum thing. Thanks.
  7. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,763
    675
    9,110
    Since 2006
    Cameron Yee
    So what exactly causes this? I've run across it once and just gently massaged it out.
  8. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Curious fingers?
