Denon OSD?
Discussion in 'Archived Threads 2001-2004' started by Jon Duke, Aug 27, 2002.
  1. Jon Duke
    Jon Duke Stunt Coordinator
    Jun 14, 2002
    107
    I'm looking at picking up the Denon 1803 in a couple weeks, but I was curious if this model supported on screen display. After looking over the Denon website it appeared that none of their models listed OSD as a feature on any of their receivers. So, do any Denon receivers have OSD, and specifically, will the 1803?
    thanks in advance
  2. Rob Higgins
    Rob Higgins Agent
    Mar 25, 2001
    25
    Jon-
    I have the 3801 and it has OSD. I would assume the model you are referring to also supports it. Although the website may not refer to this specific feature...I know of no model that doesn't have OSD.
    Good Luck,
    Rob
  3. Albert_L
    Albert_L Agent
    Jul 11, 2002
    36
    The 2802 does list OSD on its pdf spec sheet but I too didn't see anything for the 1803. I am reconsidering the 1803 now.
  4. Russ Dunn
    Russ Dunn Extra
    Aug 8, 2002
    15
    I had the 1802 for a few weeks. Unless I missed it somewhere in the manual, It did not have OSD. I too am waiting for the 1803, but have not heard about OSD as a new feature.
    Russ
