Denon DVD recommendations
Discussion in 'Playback Devices' started by Jack Heckler, Feb 20, 2006.
  1. Jack Heckler
    Jack Heckler Extra
    Jan 18, 1999
    22
    I am rebuilding my AV system after moving into a condo. Have a Denon 2805 receiver, Paradigm Studio 20 fronts, Paradigm CC-350 center, no rears at the moment, and a 1998 Sony S3000 DVD player. Although a great DVD player at the time, the Sony is lacking for today's HD formats.
    I am leaning towards a Denon DVD-1920 or 2910 to replace the Sony. They can both provide 720p or 1080i signals for my 42" Sammy DLP and I would assume they would both send a similar digital audio signal to the 2805...so is there any reason the spend an extra $250 for the 2910?? I am looking for some "reasonably-priced" excellence for both DVD AV performance and for 2-channel CD playback.
    Thanks...Jack
  2. mark tu
    mark tu Extra
    Nov 27, 2005
    16
    The 2910 adds more memory buffering, the DVI-D plug, SACD and has a aluminum faceplate as opposed to the plastic one one the 1910 and a few other processing features. It is well worth the extra $250...
    Mark
  3. Jack Heckler
    Jack Heckler Extra
    Jan 18, 1999
    22
    Mark...I see that you have the 2910. Do you use it as your main CD player? If so, I assume that you are happy with standard CD playback?
  4. Nathan_R
    Nathan_R Supporting Actor
    Dec 4, 2000
    717
    For what it's worth, the 1920 does SACD, as well.
    I have owned both, and the 2910 is, of course, the better player. It is well worth the $250 more.
  5. Jack Heckler
    Jack Heckler Extra
    Jan 18, 1999
    22
    Thanks Nathan, that makes it 2 for 2 in favor of the 2910! Since you have owned both, besides the obvious differences in features, is there a noticeable difference in the video and audio outputs of the two players? I keep thinking that if I send a digital video signal via HDMI to my TV and a digital audio signal via coax or optical to my AVR-2805, there would not be that much difference between them.
  6. Nathan_R
    Dec 4, 2000
    717
    I didn't notice a difference in the HDMI video qualities of the two, but the 2910 was definitely the cleaner of the two audio-wise.
  7. Jack Heckler
    Jack Heckler Extra
    Jan 18, 1999
    22
    One last question Nathan...were the audio connections the same for both players and what type of output did you use?
  8. Nathan_R
    Dec 4, 2000
    717
    They both have HDMI, digital coax, optical, and analog outputs. I use digital coax for movies/cds and analog for multichannel. I played with HDMI audio a bit, but without the ability to pass SACD through it, I decided to bypass it entirely as an audio output.
  9. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    You can only pass DVD-A through the HDMI?
  10. Nathan_R
    Dec 4, 2000
    717
    Yes, as far as multichannel formats go, only DVD-A is supported in the current spec. HDMI 1.3 is supposed to change that. As it stands, HDMI passes DD and DTS just fine, though.
