Denon DVD-2200 setup menu questions
Discussion in 'Playback Devices' started by Ben_wood, Feb 21, 2004.
  1. Ben_wood
    Ben_wood Stunt Coordinator
    Jun 21, 2002
    234
    I want to make sure I am setting up my 2200 correctly for M/C SACD and DVD-A playback. Can anyone (like KeithH or John Garcia) give me some advice on a few options:
    1) Digital out (normal or PCM)?
    2) LPCM (44.1 kHz/48 kHz) (off or on)?
    3) Filter (off or on)?
    I have the audio channel set to M/C, Super Audio CD set to multi, and "Player mode" set to audio.
    Thanks in advance for any pointers!
  2. Ben_wood
    Jun 21, 2002
    234
    bump. . .
  3. Neil White
    Neil White Supporting Actor
    Jan 8, 1999
    551
    1) Normal (else you will down-convert DD to PCM)
    2) Off (to allow full 96KHz out if a disc is NOT copy-protected)
    3) Not sure, probably off
    N
  4. jeff glowinski
    jeff glowinski Auditioning
    Dec 5, 2002
    9
    1) Normal
    2) Off
    3) On
    Read the Tech Paper on the denon website for the DVD2900 player. It walks you through these settings, as well as calibrating for the lower bass output.
  5. Ben_wood
    Jun 21, 2002
    234
    Thanks guys for the help!
