Denon: "Direct" vs "Stereo"
Discussion in 'Archived Threads 2001-2004' started by Craig_B, Oct 1, 2002.
  1. Craig_B
    Craig_B Agent
    Mar 5, 2002
    25
    I have a 3802 with all speakers set to small and a sub. I was wondering what the difference is between Direct and Stereo modes when listinening to a standard CD?
    What setting do most people use to listen to 2 channel music?
    Craig
  2. Kirk Gunn
    Kirk Gunn Screenwriter
    Aug 16, 1999
    1,609
    I've got a 3300 with a Pioneer 100 CD Jukebox connected via optical with Energy e:XL 16's. I can't tell the difference and usually listen in "Stereo".
    With some receivers, Direct will bypass the Sub, but most Denon's do not, to my knowledge.
  3. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    I have never been able to hear a difference between STEREO and DIRECT or PURE DIRECT for that matter on my 4802 + Paradigm Monitor 7s. I even posted about it, you will find it if you search with "direct" and "overrated". Perhaps "Holadem" would help [​IMG]
    In any case, my sub definitly works in DIRECT or PURE DIRECT mode, though I read that Denon does some ungodly thing with that analog crossover - double bass I believe.
    I just use stereo, because I am sure I ain't getting no double bass, and I can't hear a difference!
    Holadem
  4. Brian O
    Brian O Second Unit
    Apr 27, 1999
    284
    On my 3300, the Direct mode sounds lifeless to me. I prefer a bump on the tone controls with this receiver, so I use the Stereo mode.
  5. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    In a "pure direct" mode you are strictly passing analog signals to the left and right speakers. There are stipulations with the 3802 in that you have to set your sub level to OFF to get a true direct mode. If you have the sub at -12 or higher then the signal is getting sent through the receivers DACs - that bad.
    It sounds very much better than stereo. Slap in a good recording or SACD and watch the 3802 butcher it in stereo mode.
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Direct does not bypass the sub. Bass management and tone controls are bypassed = no processing. Whatever comes in, is what should be coming out, adding only the sonic signature of the amp section, not any of the circuitry in the receiver's loop. The sub is not part of a normal stereo track.
    As for "needing" tone controls, if it doesn't sound good with them flat, you've started in the wrong place, IMO. That's kind of like buying a brand new car and painting it a different color because it wasn't the color you wanted when you bought it.
  7. AustinKW
    AustinKW Stunt Coordinator
    May 30, 2002
    169
    Craig,
    The 3802's direct mode sends the signal directly to the amps. It ALSO sends the signal to the A/D converter and bass management processor to extract the low frequency content ONLY and sends it to the sub. That's why you need to run the sub volume past -12 to "OFF" to get pure analog direct to your speaks. Stereo mode digitizes the signal and processes it according to your settings.
    Austin
  8. David Berry
    David Berry Stunt Coordinator
    May 9, 2002
    150
    Craig,
    If you have a look at the Denon 3802's manual, near the back there are charts as to what is turned on when using the different modes (i.e. Direct, Stereo, DPL II, etc.). The only difference between the Direct and Stereo mode, according to the manual, is that the tone controls will be in the audio path with respect to the Stereo setting and conversely not when it is in the Direct setting.
    I used to listen to the Direct setting with the sub still on (you can turn it off by setting the sub channel one notch below -12 dB - it will say "OFF" or "SUB OFF" on the display if you do this). As I now have a SACD player hooked up via the "EXT-IN", it bypasses everything except individual channel volume settings.
    Good explanation Austin.
  9. AustinKW
    May 30, 2002
    169
    Hi David,
    One thing you might want to try with the SACD is to run a pair of interconnects from the 2-ch SACD output into an unused set of analog inputs on the receiver. Then, set the input to "Direct" mode. You get analog pass-through to the amps PLUS the sub will output the lows that your mains are incapable of producing. You'll probably have to fiddle with your crossover settings in both the receiver and at the sub so you get a smooth transition where your mains leave off. After a bit of twiddling, I find this setup works exceptionally well for stereo SACD (ie. Stones Remasters). Let me know what you think if you give it a shot. Good luck.
    Austin
  10. David Berry
    May 9, 2002
    150
    Thanks for the suggestion. I am always willing to try out different things on my system.
  11. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I always use direct mode for two channel listening. No tone controls for me and it sounds phenomenal. I only have the 3802 as the preamp and the amp duties are handled by a Proceed BPA2.
  12. AustinKW
    May 30, 2002
    169
    Yogi,
    The question is: do you listen "direct" with or without sub? If without (sub set to -13), then you're analog direct from preouts to your amp. If with, then your sub preout will be sending sub-80Hz (assuming global crossover set to 80Hz) signal and your main preouts will be sending full-range (20-20k) to your amp. How do you handle the overlap? IOW, if your mains go to 35Hz, you'll be getting 35-80 from your mains and 20-80 from your sub (double-bass).
    Austin
  13. Gordon B
    Gordon B Agent
    Jan 8, 2001
    32
    The double bass sounds like what is happening with my Denon 4800 in direct mode. In stereo mode, calibrating my double SVS Ultras with my mains was no problem. In direct mode, no matter how low I turn down the sub level control on the 4800 compared to the mains, CD music sounds way too bassy. I have mains (B&W 7NTs)set to small, sub on. Haven't tried turning the sub off to see what happens. And don't those Denon manuals suck?
  14. JohnDG
    JohnDG Stunt Coordinator
    Jul 15, 2000
    238
    If you are running "Stereo," with tone controls, "Off:" what is the difference between "Direct" and "Stereo?"
    jdg
  15. David Berry
    May 9, 2002
    150
    John,
    If you mean with the "Tone Defeat" turned on (thus bypassing the tone circuitry) and in the "Stereo" setting, I have no clue. The manual states nothing in this regard. Perhaps you could phone Denon and ask that specific technical question.
  16. Ron Reda
    Ron Reda Cinematographer
    Jul 27, 2001
    2,276
    2
    I listen to my 3802 in "direct" mode (along with a two-channel Odyssey Stratos amp) with the sub off and it sounds great to my ears. To me, the "stereo" mode just sounds too "sparkly" like the highs are being boosted. The direct mode just sounded more natural.
  17. AustinKW
    May 30, 2002
    169
    Hi John,
    "Stereo" goes through A/D, Bass Management, D/A, then on to the amps (or preouts). "Direct" goes right to the amps (or preouts) without any signal manipulation. The cool thing about Direct is that a second "copy" of the signal IS processed and bass content is extracted from it and sent to the sub. This gives you a unique hybrid for high-resolution 2-channel sources like SACD - a straight-through path for the full-range signal AND low bass to your sub. With careful manipulation of the crossover settings (receiver and sub), a seamless transition between mains and sub can be achieved and 2-channel sources absolutely shine.
    BTW, the "Pure Direct" mode on some Denon models shuts off digital, video and display circuitry as well so there is less potential interference with the source signal.
  18. David Berry
    May 9, 2002
    150
    Austin,
    I had wrote almost that exact same thing in my my previous post (i.e. Stereo goes through AD, BM, DA) but was not close to 100% sure so I deleted it prior to posting. Where did you get your information from? Secondly, from this, if one already has the signal coming in via a digital line, it goes directly to BM. Correct?
  19. kevitra
    kevitra Second Unit
    Apr 24, 2002
    364
    I can easily hear a difference between Direct and Stereo on my 3802 with ACI Sapphire IIIs (using an external amp, or even the internal amp). Direct sounds much more 'natural' than stereo.
  20. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    No sub in direct mode for me. I used to use ext-in before but I couldn't really tell the difference without the sub so I started using direct instead.
