Denon Channel levels
Discussion in 'Archived Threads 2001-2004' started by Ammon, Jan 13, 2003.
  1. Ammon
    Ammon Stunt Coordinator
    Aug 26, 2002
    129
    Is ti best to use the Denon channel leveling on the receiver or use a program such as Avia or THX Optimizer? What is the best way to get speakers leveled correctly with my receiver? I have the Denon 4802 by the way.
  2. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    The conventional wisdom is that the built-in channel leveler is a good start, but a disc like Avia is better.
  3. JamesKr
    JamesKr Agent
    Dec 25, 2002
    27
    A cheaper alternative than Avia would be Sound & Vision Home Theater Tune-up. It's made by Ovation which also makes Avia.
  4. peter m. wilson
    peter m. wilson Stunt Coordinator
    Oct 25, 2002
    218
    hi,
    don't forget an SPL meter from Radio Shack. it will help balance all your sound to the sweetspot in your room.
    peter m.
