Denon CD player skips when walking across floor???
Discussion in 'Playback Devices' started by DaveEbby, Apr 18, 2005.
  1. DaveEbby
    DaveEbby Auditioning
    Nov 22, 2004
    3
    I have have a older Denon DC?-970 I pulled out to use.
    I have not used it in years. I don't recall this as a issue
    when it went to storage. Problem is it skips really easy.Sometimes just walking across the room in front of it will make it skip. Wondered if there was something I could do about it or check.
  2. DaveEbby
    Nov 22, 2004
    3
    Anyone?
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    I dunno, I would certainly clean the main laser lens thingy, especially if it has been not used for quite a while.
    I mean, but if your floor vibrates it real good, relocation of sorts may be the only real solution.
    Is it in the same vertical plain as you DVD player that does not skip? If it's not maybe try that.
