DmitryS
- Aug 8, 2003
Hello.
I just set up Denon AVR883 receiver, and have some questions that friendly users like you may be able to answer.
1.What is up with the volume? I start DVD player and comfortable volume level is at –25. For SAT/TV is at –20. The volume range of the receiver is –70 to 18. Is this normal or my settings are not correct?
2.What is TONE DEF? Should I have it on or off?
3.I get Digital displayed on the display when watching DVD, however, I do not get Dolby Digital (logo) on the display. It is right under the Dolby Surround (orange logo). Do I need to set the DVD to DD, DTS bit stream?
4.I use BOSE Acoustmas 6. Should the speakers be Small or Large?
5.Do I need to adjust level for each speaker independently, and what should it be?
These receivers get more and more complicated each year. So I really appreciate your help.
