Denon avr 4802 x Marantz SR 8200
Discussion in 'Archived Threads 2001-2004' started by bruno mendonca, Apr 12, 2002.
  1. bruno mendonca
    bruno mendonca Auditioning
    Mar 27, 2002
    10
    Hello people,
    I know, is a difficult choise ,but someone can tell me any comments about this units.
    The denon is 7.1 , marantz 6.1 ch
    the marantz is 192/24 decoder , denon 96/24
    Marantz THX select , denon THX ultra
    Many people like marantz receivers , sounds better . Anothers says the same about of denons
    Is a question of listen this beautiful machines, but someone give me opinions about
    best regards
    bruno mendonca
  2. Dennis B
    Dennis B Stunt Coordinator
    Nov 1, 2001
    189
    Hello Bruno,
    I guess you know what I think... [​IMG]
    Do a search on the receivers and you'll find a lot of information.
    Good luck!
  3. BobK
    BobK Extra
    Mar 9, 2002
    16
    Hi Bruno,
    I have a 4802 and absolutely love it. Both receivers are decent, I just think you need to listen to each and deceide on the one that best fits your needs.[​IMG]
    BobK
  4. bruno mendonca
    Mar 27, 2002
    10
    hi bobk
    is that the question ! listen to decide. but where I am is very dificult listen both this units.
    thanks any way
    bruno
  5. chrisden
    chrisden Agent
    Apr 10, 2002
    41
    [​IMG]
    Bruno,
    In the U.S., the Marantz SR 8200 is about $1000 less than the Denon 4802. I have the 8200 and love its sound, remote and it is upgradable via RS232 port. I am running Paradigm Monitor 11 speakers and the combination is awe-inspiring.
  6. bruno mendonca
    Mar 27, 2002
    10
    thanks chrisden,
    I have paradigm speakers too (reference series) and I will considerate purchase SR 8200
    thanks,
    bruno mendonca
  7. Dennis B
    Nov 1, 2001
    189
    Bruno,
    Check out the parallel thread "Marantz Receivers" for some good recommendations on the 8200.
  8. bruno mendonca
    Mar 27, 2002
    10
    Hi Dennis
    I just looking at
  9. Michael Lee
    Michael Lee Supporting Actor
    Jan 7, 1998
    652
    There is no way to determine what you would like without you actually hearing both. Marantz fans will recommend Marantz, and Denon fans will recommend Denon. There are no surprises here. A few posts later, someone is bound to stray off-topic and recommend separates. I have auditioned the Marantz and the Denon. My choice was the Denon..you ears may differ.
