Arjcm72
- Mar 2, 2008
- Chris
I am looking for any insight you guys might have between these 2 receivers. I am building a dedicated theater room and have narrowed it down to these to receivers. (Unless convensed otherwise) The problem is I don't have a good AV store in my town or area. Bestbuy is the only real source.
The speakers I am using are Def Tec UIW RLS II and RSS II in 7 channel surround sound. The subs are 2 Klipsch RW-12d. The room size is 15 x 18 x 10 tall. Total area is 2700' if that makes a difference?
All that is going to be hooked up is a Samsung Blu Ray BD-P1500, a HD DVR, and a Espon powerlite 1080 UB pro.
The biggest problem is I have no support in fine tuning and calibrating the system.
Thank you for any help.
