Denon AVR 1602 Help
Discussion in 'Archived Threads 2001-2004' started by Brian Johnson, Jan 15, 2002.
  1. Brian Johnson
    Brian Johnson Supporting Actor
    Oct 21, 2001
    739
    Just curious. I have my surround mode for the receiver set to AUTO. When I put in a dvd with dolby digital 5.1 surround it will automatically go into that mode. If the disc is DTS capable I switch to it in the dvd-disc menu & it goes into that mode. However I've notice some dvds when I pop it in the reciever will only display PROLOGIC DVD. When I see this, I switch my dvd-player sound to PCM & put the receiver into PL II Movie mode. I guess not all dvd's are created equal? Is this the correct method for the best sound for dvd's that are not DD5.1 or DTS?
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I don't have the Denon, but HK version of DPL II Logic 7 is the way I listen to non DD/DTS 5.1 DVDs via PCM. You get good sound from PCM. The other way I found to be more effective is to have the DVD player and vcr go into the t.v. and out to the receiver. By using the stereo expander from the audio mode of the t.v. you really think you got 5.1 going in a lot of applications. Hope that answers you question a bit.
  3. Haywood
    Haywood Stunt Coordinator
    Aug 12, 2000
    81
    Johnson,
    I have a 1602 and that is set to Auto mode. Any material that is not DD 5.1 or DTS I just use PL II. You should not have to make any change on the receiver, it should default to PL II automatically.
    Later Haywood [​IMG]
  4. MichaelWRX
    MichaelWRX Auditioning
    Jun 18, 2002
    9
    I have the Denon 1602 and I know what you are on about. The manual actually says that when it senses a PCM signal it will display PLII..If you want the page reference let me know.
    Cheers
    Michael
  5. Jason Bell
    Jason Bell Stunt Coordinator
    Apr 3, 2002
    175
    I have the 1802. When I first put any movie in and its at the intro or the menus it always displays PL II. Once the actual movie itself begins to play it will switch to DD 5.1 or DTS. It does this because most intros and menus are in 2 channel. So whenever the receiver detects 2 channel material it defaults to PL II. I havent ran across to many DVDs that dont contain at least DD 5.1.
