Eggert
- Jun 30, 1997
Hi,
I live in Iceland and I have a Denon AVC-A10SE (the equivalent of the AVR-4800). This fall I will be moving to the US and I am wondering wether it will be possible to use this amp in the US.
The amp is rated for a power supply of AC 230 V, and 50 Hz. I have already checked out a power transformer and I can purchase a transformer that will convert US voltage (AC 110 V, if I remember correctly) into AC 230 V.
What I am not sure about is the Hz. The transformer does not convert 60 Hz (as is used in the US) to 50 Hz (and I gathered from the guy I talked to that it is impossible or very difficult to transform the Hz) and I am not sure wether the amp can handle 60 Hz (it isn't specified, either in the manual or on the amp itself).
Any thoughts on this? Will the amp handle 60 Hz?
If I decide to purchase a new amp to use while in the US (going to school) I would probably be looking into the Denon AVR-3802. What is the best price I could find on this unit?
Best regards,
Eggert O.
Best regards,
Eggert O.
