Denon and HDMI upconversion
Discussion in 'AV Receivers' started by Paul_Dunlop, Oct 6, 2006.
  1. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hello
    I recently bought a Denon 2307ci AVR - it provides composite, S Vid, Component and HDMI
    I have a 32" Viewsonic LCD as my TV
    DVD = Pioneer DVD recorder
    SAT = ExpressVu 9200 High Def PVR
    Game system - original XBOX
    So i hooked up the AVR to the TV using HDMI
    DVD to the AVR using Component
    DVD to the SAT using Composite (no S VID on the SAT box)
    SAT to the AVR using HDMI
    XBOX to the AVR using S Video
    IT ALL WORKS!!!
    no more TV input switching! all done through the AVR!
    2 big benefits to this
    1. more simplistic for other users of the system
    2. Only 1 video cable to run through the wall (HDMI) - from the wall mounted LCD to the AVR
    I have read about this HDMI handshake problem where switching sources causes you to reboot 1 of the devices - this is not happening to me - i switched from TV to DVD and back again - no issues
    I am extremely happy with this setup
  2. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    I'm guessing that you must not have read the Denon manual.....elsewise you'd probably still be futzing with things [​IMG]
    Sounds nice...congradulations
  3. Dean L
    Dean L Stunt Coordinator
    Jan 25, 2000
    205
    Cool, you may wanna upgrade the XBOX to a component cable and games should look even better.
  4. Paul_Dunlop
    Nov 28, 2001
    318
    Good idea
    I need to get the Hi Def connection box for the XBOX - currently the box i have only supports S Video
    Hopefully i can find a used one somewhere
  5. homthtr
    homthtr Supporting Actor
    Sep 5, 2006
    519
    or maybe the Playstation 3... which will also plays Blu-ray HD DVD's!
  6. Jean D
    Jean D Screenwriter
    Mar 8, 2004
    1,329
    It's the old Xbox right? cause I have the monster component outs for the regular xbox. Perhaps we could work out a deal. I upgraded to the 360 a few months back and dont really need them anymore...or the Xbox for that matter.
    I actually need some sort of component switching device (under $80), however, I dont want any such device to do any kind of converting or scaling of the original image (which is why I cant use the Denon unless theres a way to turn off its scaling). I also need a remote so I can program macros into my remote control to do the switching automatically. anyone have any ideas?
