Denon 5803 and es/ex questions
Discussion in 'Archived Threads 2001-2004' started by Sammy Sams, Oct 12, 2002.
  1. Sammy Sams
    Sammy Sams Agent
    Sep 14, 2002
    30
    Just got new denon 5803 receiver.
    I am a little confused about the settings.
    I dont have any back speakers, just surrounds, but there are some es/ex dvds and should i be setting my receiver to something different than thx cinema to benefit from this mix?
    also, it is my understanding that i could set my receiver to collapse the rear speakers into the surrounds on es/ex type dvds. what do i do to set the receiver up for this??
    thanks
  2. DanielSmi
    DanielSmi Second Unit
    Mar 20, 2002
    455
    If you only have a 5.1 setup than the will receiver automatically encodes the sb channels into the surrounds, so you shouldn't have to change any settings. And you can still use THX Cinema for your movies you don't need anything special.
    Daniel Smith
