Denon 5800 Will Not Power Oon
Discussion in 'AV Receivers' started by Chris Ryan, Feb 15, 2004.
  1. Chris Ryan
    Chris Ryan Agent
    Apr 14, 1999
    29
    Hi:
    I have a Denon 5800 with a Sunfire Cinema Grand powering the front 5 channels at 200 x 5. The Denon and Sunfire are on their own 20-amp circuit. The reset of my components are plugged into a Monster HTPS 7000 and work fine. Today, I played some music at reference level in 7-channel stereo mode for about an hour, maybe more. (I did not stay in the room). The other three speakers are powered by the Denon at 170 x 5.
    Now the Denon will not power on. It does not even make the normal clicking noise. I tried unplugging it, waiting a few minutes, and plugging it back in. I have not tried the microprocessor re-initialization yet. That wipes all the memory. Do you think that will solve it or do I have to send it in for service? [​IMG] [​IMG]
    Chris
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    you mean no lights come on at all? if so, check the circuit and if that's ok, check for any replaceable fuses on the unit.
  3. David*RT
    David*RT Stunt Coordinator
    Jun 26, 2002
    146
    Do a hard re-set.
    Ya, so you lose the memory. Aside of the radio presets, everything is easy to program in a jiffy.
    If that fails, check the fuses. Fuses are easily replaceable.
