Denon 5800 & JBL S412P's not getting loud
Discussion in 'Archived Threads 2001-2004' started by Jon Lee, Dec 29, 2001.
  1. Jon Lee
    Jon Lee Auditioning
    Dec 29, 2001
    4
    I just got my Denon 5800 up and put in my new JBL S412P's and my volume and Bass do not seem to get very loud?
    I put in all top of the line Monster Cable's and my Bass and volume over all don't seem to be very loud no matter the settings I tweak on the 5800. Granted I am not a guru but this should not be the hard part I would think.
    Any help would be very appreciated.
    Jon Lee
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Question #1: have you calibrated your system with an SPL meter and a test disc (video essentials, Avia, etc...)?
    What material and listening mode are you using? Are we talking stereo? DD/DTS? Pro Logic?
  3. Steve Zimmerman
    Steve Zimmerman Second Unit
    Dec 6, 2001
    347
    These may be stupid questions, but do you have a subwoofer as well? Are your speakers set to "Large" or "Small" in the receiver setup?
    --Steve
  4. Jon Lee
    Jon Lee Auditioning
    Dec 29, 2001
    4
    In every mode except radio as I have not used it as such.
    It happens with both DVD's and CD's. In 5.1 Stereo, THX and Dolby.
    The speakers each have a 12" sub powered by its own 200watt supply. I have tried both Large and Small and not heard a real difference.
    I am using a Toshiba SD1200 for both audio and DVD as I have not yet started the search for a new one.
    Thanks.
  5. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    That sounds like a signal problem.... The JBLs you have do go loud! The 1200 Tosh dvd should not be a problem either. BTW... what connection do you use from the dvd to the receiver?
  6. Jon Lee
    Jon Lee Auditioning
    Dec 29, 2001
    4
    Digital for audio on the DVD Player.
    Thanks for any idea's,
  7. Danny Owens
    Danny Owens Agent
    May 30, 2000
    48
    Jon,
    Sounds like it could be a phase issue. Does it do it on everything?
    Danny
  8. Oliver
    Oliver Stunt Coordinator
    Feb 28, 1999
    102
    You should take some time to read the manuals. To me this sound like either a setting or connecting failure.
    As you have half aktive speakers as I could read bedween the lines, you should take a look if the Bass level at those power moduls are set at the right level too.
  9. Jon Lee
    Jon Lee Auditioning
    Dec 29, 2001
    4
    It has the same problem on everything I have tried.
    I have read the manual's and not come up with anything that has helped. I have had friends come over and they can not find the issue either (they have taken the manuals home and read them and come back and played with it again).
