Denon 4802 conponent switching (1 Viewer)
David Aus
I have Comcast HD Cable and just signed up for Voom HD. I want both for now. I have been unable to go from the cable box to the 4802 then to the tv, a Mitz. When I do all I get is a blue screen. The DVD player works when I hook it through the Denon so it makes me believe there is a video set up that I cant find. I only have one 1080 input on my TV or I would go that route.
Thanks for any help. David
Bob McElfresh
Hi David. Welcome to HTF! :)
What kind of cable are you using from the DVD player to the receiver then to the TV?
To do what you want to do, you must use COMPONENT video cables from every device, then another COMPONENT video cable from the receiver to the TV.
It wont work if you mix SVideo and component wires. This is because your receiver wont usually convert the different wire types into a single output.
Latest posts
OttoIsHere
