Denon 4802 and Radio Shack 15-1994 remote (1 Viewer)
Holadem
I can't get this remote to control my Denon at all, has anyone succesfully tried? It wouldn't even learn from the atkis remote. This remote is a great bang for the buck and I would hate to have to give it up.
The RS 15-1994 is the OEM version of the Cinema 7 (or is it the other way around?).
The POS remote that comes with the Denon (the atkis) is easily the worse one I have ever used :angry:
Holadem
Brian Treinen
Have you tried here: http://www.hifi-remote.com/ofa/index.shtml
The denon receiver should be either 0004 or 0160 set-up code. From there you can go to the advanced codes list and see what you can find. I've got a 3802 and didn't need to program anything directly from that remote to the RS. I also found it VERY worthwhile to buy the cable ( Link Removed ) which allows programming via PC - you'll also need to download the program and install it. But once you do tweaking the RS is a piece of cake! I've got all my macros set up to turn on and off everything - it's awesome!
Holadem
These codes don't work :frowning: The remote accepts them (AUX1) but they receiver doesn't react to it. I am at the end of my wits on this one.
Holadem
OttoIsHere
