Jim Clark
- Jan 1, 2000
I've had my 4800 since they first came out at the end of last year and have been very happy with it even though it does require a PHD to operate the monster LOL.
It recently started acting up. It now has a mind of its own and switches to DIGITAL input (according to the lights) when it's getting an analog signal from either the SAT or TV which are both analog inputs. Then it will magically switch back and work again. Sometimes even when I try to force it back to ANALOG and it shows the analog light it produces no sound.
Another important fact is that the lights showing which speakers are receiving a signal are never lit anymore no matter what input/output I am trying to use, even when the unit decides to work.
Video signals from the SAT and DVD are fine.
I have tried a microprocessor reset according to the manual and it didn't help.
I'm pretty sure it will have to go in for service but I wanted to check here first to see if anyone has had similar problems and what they did.
Thanks.
Jim
Thanks.
Jim
