Denon 3803 vs Onkyo 800 vs HK 525
Discussion in 'AV Receivers' started by Jonathan Hale, Jun 24, 2003.
  1. Jonathan Hale
    Jonathan Hale Auditioning
    Apr 1, 2003
    5
    So it's time to upgrade the receiver and I've kind of narrowed it down to these 3 receivers based on my approximate price range.
    Before I moved ahead, I wanted to get some opinions from all you expert forumites on pros and cons of each one, and your recommendations....
    Of course, I am not married to these 3 and I'm open to other brands in a similar price range with similar features.
    Any advice would be much appreciated....
  2. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    I would add the Sony DA4ES to your list (if you can find one)
    Mark
  3. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    3803; loaded with features nice prepro section for later hookup to a dedicated amp and nice neutral sounding internal amps to go with. My money is on the 3803.
  4. Jamey F
    Jamey F Stunt Coordinator
    Dec 20, 2002
    200
    I agree with yogi, but the HK 525 can be had much cheaper so if you are very budget minded it would be worth a listen. The only other feature the Denon lacks that I would be interested in is the MCACC feature of the Pioneer 45tx. It autocalibrates your speaker levels and applies a 5 band EQ to each channel. I went with the 3803 after looking at all the features.
  5. Jonathan Hale
    Apr 1, 2003
    5
    Thanks for the input everyone, I was leaning towards the Denon anyway, just wanted to make sure I wasn't missing anything before I plunk down the bucks.
  6. Kevin*Harley
    Kevin*Harley Stunt Coordinator
    Jan 15, 2003
    137
    Find a store that carries your speakers and receivers you have in mind and audition them together. Might help with your decision.
    P.S. I went with the 3803 and love it !!
  7. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Another 3803 fan here. I got it because I needed all 7 video inputs.
